どのようにすれば以下の領域を広げられますか?
Trados Studio interface with a message 'Some example provide for reducing network' and a warning 'No matches found'.
A vertical scroll bar at the edge of the Trados Studio window.
Trados Studio project view showing 'Getting Started' with a 'CM' column partially visible.Trados Studio navigation menu with 'Sample Photo Printer' and 'Getting Started' highlighted.
Parents Reply
  • 土田様
    大変お世話になっております。
    Screenshot of SDL Trados Studio 2019 Freelance Plus showing project counts with one project in progress, zero completed, and zero overdue.
    Screenshot of Trados Studio error message with a yellow question mark icon indicating an issue with software installation or updates.
    Screenshot of Trados Studio interface with an orange outline around the 'Getting Started' section, indicating a possible user focus area.
    Screenshot of computer display resolution settings showing a weight of 8.9 Kg, dimensions of 24.7 x 97 x 60.6 cm, and a resolution of 3840x2160.
    [edited by: Trados AI at 9:14 PM (GMT 0) on 28 Feb 2024]
