どのようにすれば以下の領域を広げられますか?
Trados Studio interface with a message 'Some example provide for reducing network' and a warning 'No matches found'.
A vertical scroll bar at the edge of the Trados Studio window.
Trados Studio project view showing 'Getting Started' with a 'CM' column partially visible.Trados Studio navigation menu with 'Sample Photo Printer' and 'Getting Started' highlighted.
Parents Reply
    0 Former Member in reply to SHINE
    3.現在のコンピューターの表示解像度をご教示ください。
