メモリー毎の一致率について
Tradosにおいて、一つのプロジェクトで複数のメモリーをセットして、解析したきに、メモリー毎の一致率を確認できる機能がありますでしょうか?ファイル解析は、セットした複数のメモリーによる各一致率を合理的したものしな表示されていないようです。
Parents Reply
  • Thanks
    I have created an item on our backlog for this - SDLCOM-1272.  I can't give you timelines yet but we will get to this at some point.  I used your image and this description... if you think something is missing let me know:
    The purpose of this app is to create a new analysis report batch task.  If you prepare a project with multiple TMs attached the current analysis prepares the analysis report on the basis of the best leverage you get using all TMs.
    However, if you want to know which of your TMs is providing the best leverage you can only know this by running the report again and again using each TM in turn and then comparing the analysis results.
    This app should create a report that summarises all the results, something like the image above.
