メモリー毎の一致率について
Tradosにおいて、一つのプロジェクトで複数のメモリーをセットして、解析したきに、メモリー毎の一致率を確認できる機能がありますでしょうか?ファイル解析は、セットした複数のメモリーによる各一致率を合理的したものしな表示されていないようです。
  • The only way to do this (without development) would be to run multiple analysis, one for each TM.  I'm also not sure what you are trying to achieve here unless you are just interested in being able to determine which TM gives you the best leverage for a project?  That could be quite interesting and I imagine a variation on the MT Comparison application could be useful here as it could give you a report that sumarised the leverage somehow, maybe with some sort of leverage indices, and displayed them side by side in a column.  Perhaps applying a monetary value to each one would be a good measure?
    Not sure if this even answers your question, but I like the idea of doing something like this.
