트라도스 스튜디어 2022 버전을 사용하고 있습니다.
컴퓨터를 바꾸게 되어, 트라도스를 지우고 새로 깔았는데, 활성화가 되지 않습니다.
해결 부탁드립니다.
해결 부탁드립니다.
Hi 규성 이,
You don't have a Trados 2022 license, you have a Trados 2024 - at least linked to the email you used on the forum:
You need to download, install and activate Trados 2024.
You upgraded from Trados 2022 to Trados 2024 and processed the upgrade, this means that once an upgrade is processed the activation code generated is for the edition you upgraded to, not for the previous edition.
If you wish to use Trados 2024 and Trados 2022 side-by-side on the same computer, please consult the information here:
Best regards,
Anca
Anca Stoian | RWS Group
Hi 규성 이,
Best regards,
Anca
