Setting multiple values for a metadata field using DocumentObj25.Create shows invalid entries
Some weird behavior here that is vexing me...
I making a web API call -- DocumentObj25.Create -- to create a topic in a Tridion Docs 14 environment.
For one of the metadata fields I am setting, there are multiple taxonomy values.
When I look at the created object in Publication Manager, two of the three values are listed as invalid.
I performed the same operation manually in Publication Manager and looked at the log to see how Publication Manager was passing the metadata via the same API call. The metadata structure looks exactly like the one I am passing with my API call, but the result is correct. The values are not listed as invalid.
Here is what my metadata looks like:
<ishfields>
<ishfield name="FTITLE" level="logical" xml:space="preserve">Name of my topic</ishfield>
<ishfield name="FCUSTOMFIELD1" level="version" xml:space="preserve" ishvaluetype="id">17573177, 17574057</ishfield>
<ishfield name="DOC-LANGUAGE" level="lng" xml:space="preserve">en-US</ishfield>
<ishfield name="VERSION" level="version" xml:space="preserve">1</ishfield>
<ishfield name="FCUSTOMFIELD2" level="version" xml:space="preserve" ishvaluetype="element">86301381, 86301382, 87394644</ishfield>
</ishfields>
FCUSTOMFIELD1 is set correctly from the API call.
FCUSTOMFIELD2 is not set correctly. One value is set, but the other two are marked as invalid.
When I look at the logs in Publication Manager, when I create an object manually, I see the same exact metdata structure for FCUSTOMFIELD2 as what my API call is passing. But Publication Manager sets it correctly, and my API call does not.
Also note that if I limit the FCUSTOMFIELD2 to one value in my API call, it works without a problem.
  • Hi Mark,
    If we have two behaviors something is different. What caught my eyes first is that you pass FCUSTOMFIELD1 using ishvaluetype="id" and that you pass FCUSTOMFIELD2 over ishvaluetype="element". Is that intentional, from a product perspective I would have expected both to be aligned, or is this yours?
    Furthermore, from a CMS perspective we are just saving the value that came in. It is however your (custom) IMetadataBinding implementation that validated the incoming values in the first place upon save. And your (custom) IMetadataBinding implementation decides why it is not returning labels. So looking at the logging of that implementation on how it acts would be my next step.
  • Thanks for the quick response, Dave. The msiamtch of "id" and "element" is because I was trying both. Typically I'm using "id" for everything, but I tried using "element" to see if that fixed the problem. It did not.I'll have a look at the logging as you recommended and dig further.
  • Hi, Dave. I figured out the problem. My application is dependent on an another application that forwards the metadata to my application already configured as ishfields. There were non-breaking spaces between the commas in the field values and I didn't see them. After running out of ideas, I just guessed that maybe there was something unusual like that. When the non-breaking spaces were replaced with regular spaces, the metadata was set in TD properly. Problem solved.
