Can I configure Tridion Docs bridge UI to insert a variable for <text> element?
We have been using Tridion Docs bridge plugin to XMetaL and Oxygen to insert variables for <ph> elements and now want to also support insert variables for <text> elements.
I have updated the related DTD files to support varref and varid attributes on <text> element and have tested same successfully using DITA XML view in editors.
Now when I try to use the menu option Tridion Docs > Insert Variable...  it does not let me pick the <text> element from the file with the varid defined.
Compare this to using the menu option to pick the <ph> element from the file with the varid defined where the <ph> element shows in grey and is selectable from the Select Variable popup window.
Is there a configuration that I can make to support the use of menu option to insert variable based on <text> element?
Any advice appreciated,
Regards,
Ann
