Referencing a graphic from an Illustrations-Symbols library topic
I have a cover page for a user document that includes a small graphic in the corner of the page associated with an appliance type. I have created an Illustration-Symbol library containing the seven possible graphics.
I don't know how to reference the images in the cover page topic.
For text, I know I can use...
<p><msgph varref="text_varid" /><p>
... to pull a text phrase from a library topic.
I don't know the equivalent reference method when the item I want to reference is an image in an illustration library.
  • Not my area of expertise, but I can try to get the conversation started :)
    In your text-variable example you are in essence using a msgph xml element to reference something else. So what are you referencing for the cover image?
    • The actualy image, the LogicalId/GUID of that image?
    • Or the xml element surrounding the image, which actually brings it back tot the above text-variable sample (although nested in the variable there is an image, your wanted side effect)
  • When I used Oxygen to create the library topic for images, it put the varid for the image in the image tag, not the surrounding element.
    <p id="GUID-xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx">
    <draft-comment author="ColliTed">Rear control freestanding range/cooker</draft-comment>
    <image placement="break" href="GUID-xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx" id="IMAGE_MRQ_DGM_G1C" varid="NAFP_cover_icon_RCFS" />
    </p>
