Correct href attribute specification
Hi All,
Though there are two ways to specify an href attribute of an xref element in TridionDocs, I'd like to know which is better specification method.
- Specify only GUID: <xref href="GUID-0001"/>
- Specify GUIDs connected with # sign: <xref href="GUID-0001#GUID-0001"/>
Second specification method conform with DITA standard. However, in typical cases, first specification method also works.
I'm asking this question because first specification method causes the broken link when using chunking mechanism of DITA. If chuking is not used, all cross references will be generated properly regardless which specification method is used.
Kind regards,
Naoki
