Are images supposed to appear in author mode in oxygen using the Tridion docs authoring bridge?
What I see is an error message saying the file can't be found, which makes sense, since the value of href is a guid.
Hi, Kendall. Yes: If the authoring bridge is connected to the same Tridion Docs instance as the file you're viewing in author mode, then you should be able to see the image.
I see the error message when I'm doing something out of the ordinary -- like opening a local copy of a file (rather than checking out) for troubleshooting purposes.
Hope that helps.
Hi Kendall, have you tried adding an images to a topic in oxygen? This would be a good indication if your authoring bridge is connected properly between oxygen author and Tridion Docs. If you are not able to browse images in Publication Manager through Oxygen, you may need to reach out to your system admin to reinstall the bridge. Hope this helps...
Eh... I don't know why, but I now see image preview in oxygen. I don't know what changed...
