Adding new metadata field using DBUpgrade tool
Hi All,
I am trying to add new field in one of our outputformat's property dialog box. I succefully created a XMSetup.xml and run DBUpgradeTool following these instructions.
1.  https://docs.rws.com/801922/393838/sdl-tridion-docs-13-sp2/metadata-setup-structures
2. https://docs.rws.com/801922/396257/sdl-tridion-docs-13-sp2/running-dbupgradetool-for-xml-setup
3. Setup <ishfrmfield> in metadataconfig.xml
4. Ran following crawlers:
-- x:\InfoShare\App\Crawler\Configuration
1. UnregisterAllCrawlers.bat
2. RegisterThisCrawler.bat
3. StartDataFolderCleanup.bat
4. StartReindex.bat
5. Now I can see the field and associated LOVs in outputformat's property dialog box.
But, when I try to select the value it throws an exception "The FieldValue "XXXX" cannot be returned, because it is not initialized".
Note: I haven't tried to restart all components for example (Restart services, Restart application pools, Recycle com+ applications). If this is the issue here please let me know the instructions to restart these services. I couldn't find instruction on how to restart services in documentation centre for Tridion Docs 13 SP2.
Thanks in advance for any help with this.
Pankaj
