Deleted processing instructions being removed when doing a compare between versions
I'm comparing v1 to v2 of a publication.
In a topic in v1 it has a processing instruction
The topic is versioned up in the v2 version of the publication
The processing instruction is removed from v2 of the topic
When I do a publish with comparison of v1 to v2, the processing instruction in the combined topic (with the compare PIs) is missing.
When I look at the export folder, v1 is correct and has the pi and v2 is correct also and is missing the pi.
But in the cmp dir the pi is missing altogether.
Is there a way to prevent PIs from being deleted in a compare when they have been deleted in the current version?
Mario Madunic
  • How do versioning systems represent deletion? With git a deletion is clearly defined or part of a rename.
    There are other problems with the comparison that is provided. For example, if anyone uses xmetal or oxygen, the markup they add in processing instructions is compared and can result in failures.
    The root cause being software that is not XML aware
  • Hi Mario,
    Not completely sure what you are trying to achieve... comparing processing-instructions like <?oxy-... or <?xm-... during a publish compare?
    Do you expect a compare of processing-instructions to show up? I would be interested in the business purpose, if you don't mind sharing.
    The key thing is that the Compare engine (ChangeTracker) actually uses processing-instructions <?ish... to identify where inserts or deletes are. See TD14SP4 - IPublishComparePlugin - IshPublishCompare In turn nesting of processing-instructions is not allowed, so I can imagine that the compare simply ignores any incoming processing-instructions altogether.
    Appologies if I misunderstood your question.
  • We are using PIs for numbering of topics in a map and the numbering has to be predefined and does not change version to version. So when a topic is deleted in a map in v2, it still must be published using the PI that existed in v1.
    If a PI existed in one version and is deleted in a new version, it should still appear when a compare is done but in between the version PIs.
    PIs are not "nested" with a compare.
