Make the CMS vlaidate against XML Schemas instead of DTDs
Hi All,
We've encountered quite an annoying issue with MathML in DITA 1.3.
During the preprocessing phase the MathML namespace declaration is dropped from <m:math> if the topic containing "the math" is referenced and used with chunk="to-content" from a map. The blame is on DITA-OT of course, I checked the Java code and we only save certain attributes in scenarios like these, the rest (including the mathml one) is ignored by the Reader.
Now I've a fix for the Java code but it'd be much nicer if we could valdiate our DITA docs against XML Schemas with default namespace declarations instead of DTDs. Is there a way to make Tridion Docs use XSDs instead of DTDs for validation purposes? I know about the ATTLIST namespace hack in DTDs but you know...that's not a very nice thing to utilize Slight smile
Regards,
Tamás
