How do I get the id of a folder object using ISHRemote?
I am trying to use ISHRemote to move folder contents and am failing to see how I get the ID for the ToFolderId parameter if I am creating the folder dynamically via ISHRemote as well
I have tried the code below but Get-IshFolder returns a folder
Move-IshFolder -IshSession $ishSession -FolderID 5061139 -ToFolderId (Get-IshFolder(Add-IshFolder -IshSession $ishSession -ParentFolderId $parentfolderID -FolderType ISHNone -FolderName $folderName -ReadAccess @("") -OwnedBy ""))
How do I get the ID values from and folder object?
Thanks in advance,
Ann
  • Hi Ann,
    Where possible the pipeline friendly objects like IshFolder or IshObject are preferred in ISHRemote. It seems v1 cmdlet Move-IshFolder is asking for the Id (so card_id).
    $ishBaseFolder = Get-IshFolder -BaseFolder Data
    $ishBaseFolder.IshFolderRef
    # would return: 3222
    So if I may suggest a rewrite it would look like
    $ishFolder = Add-IshFolder -IshSession $ishSession -ParentFolderId $parentfolderID -FolderType ISHNone -FolderName $folderName -ReadAccess @("") -OwnedBy "")
    Move-IshFolder -IshSession $ishSession -FolderId 5061139 -ToFolderId $ishFolder.IshFolderRef
    The Add-IshFolder cmdlet returns the just created folder for further usage, so the Get-IshFolder was superfluous.
