How can I troubleshoot 404 error in Publication Manager preview of a map/topic?
I am having an issue with Publication Manager (13.0.2).
I can successfully open a Publication from our SDL Tridion Docs CMS but when I click on one of the submaps within the publication it does load the map versions in the top-right window pane but it fails to load the preview in the bottom-right window pane. Instead it gives a 404-Not Found error.
The publication and submap exist in the CMS but Pub Manager is failing to load preview.
Can anyone advise where I can start troubleshooting this problem please?
Any advice appreciated,
Regards,
Ann
  • Hey Ann,
    I think the best way to troubleshoot this is by contacting support. But a few things you can try already:
    1. Check the logfiles:
    > Press the Windows Key + R on your keyboard to open the Run Dialogue
    > Enter: %localappdata%\sdl\InfoShare Client
    > Open the folder that matches your Version (for example 13.0 or 14.0)
    > Open the log Folder
    > Open Publication Manager.log and scroll to the bottom to see the most recent information
    2. Try clearing your cache:
    > Click Tools > Local Storage
    > Make sure nothing is checked out. If something is checked-out, check it in first before continuing to the next step.
    > Close Publication Manager and Open your Documents folder
    > Rename the SDL folder to something else, for example SDL.Backup
    > Open Publication Manager again and see if you can reproduce the issue
    3. Try clearing the Preview's Cache
    > Close all CLient Tools
    > Rename GeckoProfile to something else, for example GeckoProfile.Backup
  • Thanks for advice.
    We just resolved it by checking the path to SDL Tridion Docs Content Manager web site root address from Tools->Accounts->Properties->Repository.
    It was pointing to ISHWS instead of ISHCM so couldn't resolve connection to the Content Manager.
    Regards,
    Ann
