This comes up a lot. The DTD has changed or MetadataConfig.xml has changed. How do I force publication manager to synchronize with the server?
Hi Kendall,
This should happen automatically when you first open a client tool. If a file changes on the server while the client tool is open, you will need to exit and restart the client tool. If the file on the server is more recent then the client it should automatically sync. If the file on the client is more recent you should get a prompt to pick which file you want.
This files that are tag to be synchronized from the server to the client are configured in the <INFOSHARE>\Web\Author\ASP\ClientConfig\SyncInfo.xml
With clean-up we can force a full file synchronization if needed, but not normally necessary.
Best regards
For whatever reason, that doesn't happen sometimes. It might only be MetadataConfig.xml that get synchronized sporadically.
I generally tell people to restart the client. If that doesn't work and they have accounts on different servers, switch to another server and switch back. If that doesn't work, we delete/move %LOCALAPPDATA%\SDL and then people have to recreate their accounts and that forces synch. But, of course that is pretty laborious.
Hi Kendall,
If you want to look at this further please open a ticket and note you had spoken to me. We can set up a interactive meeting to look at the issue and I can show you another method to resync with out recreating accounts.
Have a nice weekend.
