With which elements can you use SDL Variables
I have searched for and found the SDL Tridion Docs documentation on SDL Variables at https://docs.sdl.com/787645/479553/sdl-tridion-docs-14/variables.
However, this does no provide any examples of the definition of the variable and varid. Does SDL have any other documentation that would go a bit deeper into demonstrating scenarios where SDL variables can be used/can't be used.
I am specifically interested to know which DITA elements I can use for variable content.
I know for example that the following DITA elements can handle variable content using the keys mechanism - topicref, xref, image, ph, keyword, term and any element that allows conref.
Where can I find out about the comparable list for SDL Variables?
Any feedback appreciated,
Regards,
Ann
  • Hi Ann,
    Not aware of any such documentation.
    We are able to use three DITA elements when declaring variables with @varid using the standard <topic> topic type, stored as a Library topic in the Resource folder:
    <keyword>
    <ph>
    <image>
    We also use a lot of keys and conrefs for variable content, but those are in the standard DITA syntax.
    Best,
    Peter
  • It may be easier to identify those elements that CANNOT accept a variable without a specialization. This is the list that FICO put together when we launched DITA, but it may be out of date now. Here's what our internal doc says:
    Although most DITA elements can contain the <ph> element, some cannot. Unless we decide to create a specialization, you will not be able to insert variables in the following elements. This is inconvenient because product names and our company name are frequently used in installation file paths, window titles, and menu cascades. Until we come up with a solution for this problem, you will need to type variable values
    into these elements.
    apiname
    cmdname
    filepath
    kwd
    menucascade
    msgblock
    msgnum
    msgph
    option
    synblk
    synnoteref
    synph
    syntaxdiagram
    systemoutput
    uicontrol
    userinput
    varname
    wintitle
  • Not having a single element to contain variable content is annoying and something I wish had been addressed in DITA 1.3.  For most variables, <ph> works.  For variable content that has to go into places like <uicontrol>, I end up defining 2 variables with the same content: one as <ph> and one as <keyword>.
