What is in ro.sync.ecss.extensions.dita.map.DITAMapCustomRuleMatcher
I am working with the SDL Tridion Docs connector to Oxygen XML Editor and am trying to understand the configuration within the trisoftdita framework that is created after installing the connector.
The SDL Tridion Docs  DITA Map framework has an associated Java class ro.sync.ecss.extensions.dita.map.DITAMapCustomRuleMatcher.
Can someone advise what this is doing?
Thanks in advance,
Ann
