How do I find out the status of the latest version of an object using ISHRemote?
Hello,
I'm trying to use ISHRemote to find out the latest version of an object in en-us language, as well as the status of that version in en-us. I can get hold of the object like this:
$thisObject = Get-IshDocumentObj -IshSession $ishSession -LogicalId $objectID
And then I can do this to get all the version numbers of all languages:
$objectVersion = Get-IshMetadataField -IshSession $ishSession -IshObject $thisObject -ValueType Value -Level Version -Name VERSION
And in a similar way, I can get all statuses of all languages. But how do I combine these queries to get the information I need? Is Get-IshMetadataField  even the correct cmdlet, or should I be using something else?
Simo
  • Hi Simo,
    Since version 0.7 the explicit -IshSession parameter is no longer required, although it is good practice to be explicit :-) (https://github.com/sdl/ISHRemote/releases/tag/v0.7)
    On my reference system using ISHRemote v0.10 the default rendering of your first cmdlet looks like below including the status (fstatus property)
    ISHType          Title                                    LogicalId                                 Version Lang  Res   Status             ModifiedBy          ModifiedOn
    ISHModule        Something User Guide                     GUID-4C413EBB-262A-462E-89F7-030D3E4C2548 1       en-us       Released           author1
    ISHModule        Something User Guide                     GUID-4C413EBB-262A-462E-89F7-030D3E4C2548 2       en-us       Released           author2
    ISHModule        Something User Guide                     GUID-4C413EBB-262A-462E-89F7-030D3E4C2548 2       ja-jp       Translation app... ddemeyer
    ISHModule        Something User Guide                     GUID-4C413EBB-262A-462E-89F7-030D3E4C2548 3       en-us       Released           author2
    ISHModule        Something User Guide                     GUID-4C413EBB-262A-462E-89F7-030D3E4C2548 3       ja-jp       Translation app... author2
    ISHModule        Something User Guide                     GUID-4C413EBB-262A-462E-89F7-030D3E4C2548 3       zh-cn       Translation app... author2
    ISHModule        Something User Guide                     GUID-4C413EBB-262A-462E-89F7-030D3E4C2548 4       en-us       Released           author2
    Assuming that you are looking for version 4 in en-us as a hit in this example data then the below could work for you
    # First of all, you need the latest ISHRemote (at the time of writing 0.10), see github.com/.../ISHRemote how to update
    # Option 1; probably fastest using server-side filter to only retrieve you requested language for your specified LogicalId/ObjectID
    $metadataFilter = Set-IshMetadataFilterField -Level Lng -Name DOC-LANGUAGE -FilterOperator Equal -Value en-US
    $thisObject = Get-IshDocumentObj -LogicalId $objectID -MetadataFilter $metadataFilter |
                  Sort-Object -Descending -Property version_version_value |
                  Select-Object -First 1
    # Risk here is that Sort-Object sorts alphabetically, so version 1, 10, 11, 2... you expect numerically, let
    # alone sorting branches like 11.2.2 is higher than 11.1.1
    # Option 2; the CMS API allows it, but ISHRemote doesn't offer it directly, indirectly however... :-)
    # The most accurate as the filtering happens server-side for the version
    # and language, however the filtering on the right LogicalId/ObjectID happens client side so in
    # practice you are retrieving full folder content and then selecting the right one which could affect performance
    $folderPath = Get-IshDocumentObjFolderLocation -LogicalId $objectID
    $thisObject = Get-IshFolderContent -FolderPath $folderPath -VersionFilter "latest" -LanguagesFilter "en-US" |
                  Where-Object -Property IshRef -EQ -Value $objectID
    # Option 3; to come up with an idea to improve ISHRemote by some cmdlet overload and log it on GitHub
    Happy Friday!
  • Hello Dave,
    I tried your option 1, and it worked. Now I can get the status info I wanted like this:
    $objectStatus =  Get-IshMetadataField -IshObject $thisObject -ValueType Value -Level Lng -Name FSTATUS
    Thanks a lot!
    Simo
