Collaborative Review 7.7 w/latest patch Setup.bat constant failures on first install?
Running setup.bat *parameters* install fails and I have no idea why. First I could only get the parameters to actually work if they were entered before "install" which is contrary to the documentation otherthan specifing the -jh parameter needs to be before install. So I figured that out, but now it keeps failing in the build with no real reason I can understand.
Has anyone seen the error of *COLLABREVIEWHOST.ORG:8080/ContentDelivery/web/util.xql?action=ping doesn't exist?
I'm able to hit validate the web server is online via browser, and I'm also able to drill into the CD/web/ folder and see the util.xql file exists.
Any thoughts would be appreciated.
Server online and available -
