Collaborative Review 7.7 install error - could not load main class java.se.ee?
Has anyone run into the issue when trying to run the setup.bat file after the initial install of Collab Review 7.7 where no matter how you run the setup.bat your get "Error: Could not find or load main class java.se.ee"?
I've now tried this with OpenJDK 11, and with Java 8 (per recommendation of another collab review 7.7 user) and no matter what I have set up when I try to run the setup.bat file it errors around failing for find main class java.se.ee.
I've set up the Java home to the openjdk folder, to the JRE8 folder, and to the JDK8 and tried calling directly to all of them in the actual cmd command to get it online but nothing seems to solve this issue.
Anyone have an idea on how to solve this? Java runs 100% as expected otherwise and Tomcat works great with any of those java jvms set. I'm at a total loss. Command prompt showing error during setup of Collab Review 7.7. Error message reads 'Could not find or load main class java.se.ee' after attempting to start database load.
[edited by: Trados AI at 6:36 AM (GMT 0) on 5 Mar 2024]
