Translated content using the file system
My role as a DITA tools engineer has not included performing workflow related tasks. I am familiar with object levels, and I have some familiarity with the web services API. At my current job I have a task to research using multiple languages. There are no plans yet to use a translation management system.
Should it work to change the status of objects, which have translation management enabled, to "To be translated" send an export the report. Create translated copies of the exported files changing xml:lang and keeping the same GUIDs. Then use Import translations?
What I have tried is to add status transitions and inbox actions to add a Change2ToBeTranslated action and status transitions from Review to To be translated, but when I try to generate a workflow report, the transition does not appear.
In the web client there is a recycle symbol next to the status transitions. Is there some action that I need to perform?
  • I got help from support. Details that were not in the documentation were: A user with role "Translator" is required to start the export for translation. Export happens in 2 steps. The files have to be in released state before the other languages can be generated (the first step). This is done from the Translation button in the web client. The 2nd step exports the files.
    The report was started from the publication object in the web client.
    In the translation report window, you have to click in just the right place on the very bottom of the page to make the report expand (repeatedly click on the words until the window opens. Then if you click the checkbox next to files, above, it selects the files in the corresponding state.
    Aside from inbox definitions (Change2Released and Change2ToBeTranslated) and status transitions for Translator and TRANSLATORSERVICE, the file x:\InfoShare\Web\Author\ASP\XSL\WorkflowReportConfig.xm has to be modified to include status transitions.
