ishfolderquery functions/variables?
 I would like to setup an inbox that displays all content that has been in a "design" state for at least 90 days.  I need to be able to do some basic math based on the current date/time.
Basically this would be setup for a quality role to disposition components that have been sitting idle - delete the components or push them through workflow.
Took a stab at it hoping xpath was valid option but seems that isn't the case ...
<InboxQuery>
    <MetaDataCondition>
        <CardType value="CTMASTERL"/>
        <CardType value="CTMAPL"/>
        <CardType value="CTLIBL"/>
        <ISHField ref="FSTATUS" operator="equal" value="VSTATUSDESIGN" valueoption="isrcElement"/>
        <ISHField ref="FSTATUS" operator="equal" value="VSTATUSROUTING" valueoption="isrcElement"/>
        <ISHField ref="FISHLASTMODIFIEDON" operator="greaterthan" value="current-date() - xs:dayTimeDuration('P90D')" valueoption="isrcElement"/>
    </MetaDataCondition>
</InboxQuery>
Thanks.
David
  • From the top of my head the ISHField value parameter has no scripting options, so it will only accept a hardcoded value. I don't think the sliding window is feasible without 'daily' inbox configuration adjustment.
    I assume you want this in the UI (so inbox), as the corrective is different every time. Or is there a 100% rule that would allow some automation.
  • Hello Dave,
    I noticed some variables ($ME) are defined. Any others? Are those variables defined at the time they're requested/generated? It seems this is something that can't be done as a configuration but rather a customization within the ASP files.
    If you have time to explore the scripting options that would be helpful. I would very much like to make our inboxes more dynamic. This is a function of time and state. I want things to shift to higher/different priority boxes based on those two criteria.
  • Hello Dave,
    Additionally, I do not see any documentation or method to limit a ishfolderquery to a folder?  I'd like to search X folder for components that match Y criteria?
    Thanks.
    David
  • You got me on the variable $ME, which is executed in the business code. Remember that the inbox configuration is also used in the Client Tools. This in turn means not customizable over ASP. See also KC2016SP3 - Admin.XMLInboxConfiguration.xml
    The QueryFolder mechanism is basically a DocumentObj.Find operation across your repository, restricted to the Logical level (so typically no fields like Language level FSTATUS etc). See also KC2016SP3 - FolderQuery
    Custom filters like "search X folder for components that match Y criteria" and then do "move status" require some automation, where my first attempt would be using ISHRemote.
