プロジェクト設定をクリックすると「呼び出しのターゲットが例外をスローしました。」のエラーメッセージが出ます
いつも大変お世話になっております。
6月24日にFreelance Plus 2017からFreelance Plus 2019にアップグレードを行いました。
プロジェクトを作成後、プロジェクト設定をクリックすると、「呼び出しのターゲットが例外をスローしました。」のエラーメッセージが出ます。
今回使用したのはExcelファイルです。以前にsrtファイルでプロジェクトを作成しましたが、その際もプロジェクト設定ができませんでした。
解決のための手順をご教示いただければ幸いです。
  • Hello ,
    Could you please post the full error stack please and tell us exactly what you are trying to do.
    -Error message popup with instructions: 1) Click on the icon, 2) Save the XML file to your desktop, 3) Add file to the thread.
    Are you trying to create a project based on an Excel file and/or an SRT file type?
    After migrating to Studio 2019- have you updated to the latest release?
    SDL TRADOS STUDIO 2019 SR2+ supports SRT natively. If you haven't updated, you will need the SRT filetype and Studio subtitling app.
    https://appstore.sdl.com/language/list/?search=SRT
    Oana Nagy | QA Engineer | RWS Group
    [edited by: Trados AI at 9:46 PM (GMT 0) on 28 Feb 2024]
  • Thank you.
    As I posted a question in Japanese, I expect an answer from the Japanese team.
    [Dear Japanese team]
    I look forward to your kind reply. Thank you.
    0 Former Member in reply to Naoko ORITO
    Hi , ,
    Can I get some advice from you about this stack trace above?
  • It looks as though the problem might be coming from the translation memory settings page. Try removing the TMs from the template being used for the project creation and then try to create the project again.
    If that doesn't help you should try a full Studio reset.  But I'd try the TM route first as it might save having to try a reset.
    I have just created another test project with an Excel source file and the problem persists.
    More precisely, it occurs after the project creation, and when I click on the project setting button.
    (my purpose for the project setting is TM setting, naturally!)
    As my Studio 2019 is brand new and I do not have any projects on it. That said, it is not a problem to try a reset.
    If you think it is better to do so, please advise me on how to do it.
    Thank you very much!
    念のため、Trados Studioのリセットをお試しください。下記のブログをお読みいただければと存じます。
    https://www.sdltrados.com/jp/blog/reset-trados-setting.html
  • 早速にご教示いただきまして、ありがとうございます。
    明日以降に、追って報告させていただきます。
  • Hi
    I tried a reset and it was successful.
    However, when I created a new test project and see what happened, the same problem persists.
    Please see the attached file.
    Thank you very much in advance,
    いったんTrados Studioを終了し、下記のフォルダにある「Default.sdltpl」というファイルを「Default_old.sdltpl」とリネームしてください。
    C:\Users\ktsuchida\Documents\Studio 2019\Project Templates
    その後Trados Studioを起動し、新規プロジェクトを作成していただけますでしょうか。どうぞよろしくお願いいたします。
  • ご返信ありがとうございます。
    早速、ファイルをリネームした後、新規プロジェクトを作成してみましたが、
    残念なことに同じエラーメッセージが出てきてしまいます。
    エラー発生の詳細情報を添付いたします。
    <SDLErrorDetails time="2020/07/09 8:34:17">
      <ErrorMessage>呼び出しのターゲットが例外をスローしました。</ErrorMessage>
      <Exception>
        <Type>System.Reflection.TargetInvocationException, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</Type>
        <HelpLink />
        <Source>mscorlib</Source>
        <HResult>-2146232828</HResult>
        <StackTrace><![CDATA[   場所 System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
       場所 System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
       場所 System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
       場所 System.Activator.CreateInstance[T]()
       場所 Sdl.Desktop.Platform.Settings.SettingsPageReference`1.Initialize()
       場所 Sdl.Desktop.Platform.Implementation.Settings.AbstractSettingsHost.EnsurePageInitialized(ISettingsPageReference r)
       場所 Sdl.Desktop.Platform.Implementation.Settings.AbstractSettingsHost.ActivateSettingsPageCategory(String[] path)
       場所 Sdl.TranslationStudio.ProjectManagement.ProjectOperations.ProjectSettingsOperation.<>c__DisplayClass3_0.<Execute>b__0(ISettingsDialog d)
       場所 Sdl.TranslationStudio.ProjectManagement.Actions.ProjectSettingsDialogHelper.Show(IProject project, IProjectManagementService service, ConfigureProjectSettingsDialogDelegate configureProjectSettingsDialog)
       場所 Sdl.TranslationStudio.ProjectManagement.ProjectOperations.ProjectSettingsOperation.Execute(IProject project, String operationId, Object[] args)
       場所 Sdl.ProjectApi.Implementation.Operations.ProjectOperationComposite.Execute(IProject project, String operationId, Object[] args)
       場所 Sdl.ProjectApi.Implementation.Project.ExecuteOperation(String operationId, Object[] args)
       場所 Sdl.TranslationStudio.Editor.TranslationEditor.Actions.AbstractProjectSettingsAction.Execute()
       場所 Sdl.Desktop.Platform.Implementation.CommandBars.ActionService.<>c__DisplayClass30_0.<ExecuteAction>b__0()
       場所 Sdl.Desktop.Platform.Implementation.CommandBars.ActionService.ExecuteAction(IAction action, ActionOrigin origin, Boolean allowToggle)
       場所 Sdl.Desktop.Platform.WinForms.IgCommandBarAction.Execute()
       場所 Sdl.Desktop.Platform.WinForms.IgCommandBarAction._lazyButtonTool_ToolClick(Object sender, ToolClickEventArgs e)
       場所 Infragistics.Win.UltraWinToolbars.ToolBase.OnToolClick(ToolClickEventArgs e)
       場所 Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.OnToolClick(ToolClickEventArgs e)
       場所 Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.FireEvent(ToolbarEventIds id, EventArgs e)
       場所 Infragistics.Win.UltraWinToolbars.ToolBase.OnToolClick()
       場所 Infragistics.Win.UltraWinToolbars.ButtonToolUIElement.DoClickProcessing(MouseEventArgs e)
       場所 Infragistics.Win.UltraWinToolbars.ButtonToolUIElement.OnMouseUp(MouseEventArgs e)
       場所 Infragistics.Win.ControlUIElementBase.ProcessMouseUpHelper(Object sender, MouseEventArgs e)
       場所 Infragistics.Win.ControlUIElementBase.ProcessMouseUp(Object sender, MouseEventArgs e)
       場所 Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
       場所 Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea.OnMouseUp(MouseEventArgs e)
       場所 System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)]]></StackTrace>
        <InnerException>
          <HelpLink />
          <Source>System.Core</Source>
          <StackTrace><![CDATA[   場所 System.Linq.Enumerable.First[TSource](IEnumerable`1 source)
       場所 Sdl.TranslationStudio.Common.TranslationMemory.TranslationMemoriesControl..ctor()
       場所 Sdl.TranslationStudio.ProjectManagement.Settings.TranslationMemoriesSettingsPageControl.InitializeComponent()
       場所 Sdl.TranslationStudio.ProjectManagement.Settings.TranslationMemoriesSettingsPageControl..ctor()
       場所 Sdl.TranslationStudio.ProjectManagement.Settings.TranslationMemoriesSettingsPage..ctor()]]></StackTrace>
        </InnerException>
      </Exception>
      <Environment>
        <EntryAssemblyFileVersion>15.2.0.1041</EntryAssemblyFileVersion>
        <CodePage>932</CodePage>
        <LoggedOnUser>LAPTOP-UDQE1LEG\naokoorito</LoggedOnUser>
        <ComputerName>LAPTOP-UDQE1LEG</ComputerName>
        <PhysicalMemory>4084100 MB</PhysicalMemory>
      </Environment>
    </SDLErrorDetails>
    +1 Former Member in reply to Naoko ORITO
    ご連絡ありがとうございました。下記のブログを参考に、SDL Freshstartというツールをお試しいただければと存じます。
    お手数をおかけしております。どうぞよろしくお願い申し上げます。
  • やっと解決しました。
    サポートをいただき、誠にありがとうございました。
    The issue is solved. Thank you again for your kind help!
