This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
Language Weaver Edge 8.5.5 has been released
Hi all,
I'm happy to announce that Language Weaver Edge 8.5.5 has been released and is now available from our download servers.
This version is a patch release that contains the following improvements and fixes:
What's new?
  • Added Support for *.zip archive translation in the Translate User Interface
  • Added UI and REST API for Event Log Configuration
  • Added batch delete for various REST API endpoints (users, dictionaries, feedback, labels and translations)
  • Added Customizable Columns display for Tables
  • Added Preferred order for TLS Cipher Suites with Forward Secrecy
Fixes
  • Fixed Automatic approval of imported User feedback with option "Approve all"
  • Fixed Dynamic PU Allocation translation rate fluctuations
  • Fixed Files Drop Area on the Translate page to include the entire text area box
  • Fixed EULA agreement not being displayed for first time logins
  • Removed Webhook trigger for synchronous translation
  • Fixed GroupShare Project Fetching when Interactive Translation Editor is set to No
  • Fixed Language Detection when configured to detect installed languages only
  • Fixed Language Detection maximum input size increased to 100 MB, and the value is now configurable
  • Fixed Theme support for SAML and SMTP pages
  • Fixed GPU Memory Monitoring Metrics
  • Fixed Embedded API translation of Docx input
License consideration when upgrading:
  • If you are already using Language Weaver Edge 8.5.2, 8.5.3 or 8.5.4, you can safely upgrade to 8.5.5 and no new license is needed.
  • If you are upgrading from 8.5.0 or 8.5.1 on Windows (Bare metal / VM) or Linux (Bare metal), you can safely upgrade to 8.5.5 and no new license is needed.
  • If you are upgrading from 8.5.0 or 8.5.1 on Linux Virtual Machines, due to security improvements introduced in 8.5.2, the service will now run with a non privileged user. In some virtual environments, a new license may be needed after the upgrade. If you are running on Linux Virtual Machines, you may want to get a new 8.5.5 license generated before running the upgrade. Please ask a new license through your gateway account, with the current myhosts.json of your Edge setup.
  • Direct upgrade from other 8.X previous releases is supported, but an 8.5 license will be required. The new license can be requested through your gateway account, and it can be generated based on your current myhosts.json file (there is no need to wait for the upgrade to be done to get the license generated - we can generate the license in advance so it can be available when the upgrade is performed).
We hope you'll enjoy this new release, and please let us know if you have any questions.
