This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
Language Weaver Edge 8.5.4 has been released
Hi all,
I'm happy to announce that Language Weaver Edge 8.5.4 has been released and is now available from our download servers.
This version is a patch release that contains the following improvements and fixes:
What's new?
  • Translation status progress bar in now available on the Translate page
  • New UI localization languages supported: Arabic, Chinese, German, Japanese, Korean, Spanish
  • Dynamic PU allocation is now supported, allowing flexibility when handling spikes in translation demand
  • Improved API integration capabilities with support of Webhooks: a new UI configuration page and related REST API is now available to administrators.
  • The Feedback page now includes an option to import or export feedback (in tmx format)
  • The application logs can now be sent to an external LogStash (ELK) server for better aggregation, filtering, and visualization
  • Auditing of user/admins actions is now supported by new event logs
  • Add ability to map the linguist user role to a SAML/LDAP group
  • Improved Image OCR using the standard detector, or with ABBYY if enabled
  • Dictionary REST API now supports modifying individual terms
  • Added documentation for the Feedback REST API
  • Improved layout of the Deployments page
  • Added monitoring charts for the Host: CPU, Memory, Disk and GPU usage
  • New Reporting username filter option, "all", that shows total LP usage per user
  • Improved Docker and Kubernetes support
  • GPU batching mode is enabled by default; allows for faster translation rates when using GPUs
  • Locally encrypted files now use AES256 (instead of AES128)
Fixes
  • Improve http authentication token security by using cookies instead of local storage
  • Fix security issue when exporting Dictionary in xlsx format
  • Prevent rare crash caused by an XLIFF input containing only BOM characters in its content
  • Fix licensing issue preventing verification if the "minRSAPubKeyBitLength" Group Policy has been set to 2048
  • Fix language detection issue causing JobEngines to only detect locally installed LPs when the priority is set to "Installed Languages Only"
  • Improved language detection differentiation between Chinese Simplified and Traditional
  • Display the user role in My Account page
  • Reduced memory usage of the api-gateway process
  • Fix the translate page to support displaying multiple queued translations that have the same file name
  • Fix JobEngine delay when host is resuming from a sleep power state
License consideration when upgrading:
  • If you are already using Language Weaver Edge 8.5.2 or 8.5.3, you can safely upgrade to 8.5.4 and no new license is needed.
  • If you are upgrading from 8.5.0 or 8.5.1 on Windows (Bare metal / VM) or Linux (Bare metal), you can safely upgrade to 8.5.4 and no new license is needed.
  • If you are upgrading from 8.5.0 or 8.5.1 on Linux Virtual Machines, due to security improvements introduced in 8.5.2, the service will now run with a non privileged user. In some virtual environments, a new license may be needed after the upgrade. If you are running on Linux Virtual Machines, you may want to get a new 8.5.4 license generated before running the upgrade. Please ask a new license through your gateway account, with the current myhosts.json of your Edge setup.
  • Direct upgrade from other 8.X previous releases is supported, but an 8.5 license will be required. The new license can be requested through your gateway account, and it can be generated based on your current myhosts.json file (there is no need to wait for the upgrade to be done to get the license generated - we can generate the license in advance so it can be available when the upgrade is performed).
We hope you'll enjoy this new release, and please let us know if you have any questions.
