MT Edge 8.5.2 has been released
Hi all,
I'm happy to announce that MT Edge 8.5.2 has been released and is now available from our download servers.
This version is a patch release that contains the following fixes and improvements:
  • Redesigned Translate UI with a clean and easy to use interface
    • Add UI direction-toggle to easily switch the source and target languages
    • Align target language selection with the target language text box
    • Add more visible "Clear text" option to clear the source text box
    • Move Dictionary selection under Settings
    • Add UI option to highlight target segments in the Translate page
    • Add UI option to include the source text when copying content
  • Add support for UI Localization: UI is now available in English and French.
  • Add support for UI customization Themes (logo, colors)
  • Add new User roles for finer permissions control (Translator, Linguist, Admin and Super Admin)
  • Add Monitoring page to display operational metrics, such as number of users connected, number of API calls and more
  • Add new Dictionary Import / Export options
    • Add Dictionary import option for MultiTerm xml files
    • Add Dictionary import/export option from/to Excel
  • Add Manage Labels page
  • Add Security improvements:
    • Add support for encryption of Translation Queue documents on disk
    • Add support for querying users in nested AD groups
    • Add support for http headers configuration
    • Change the Linux MTE service to run as a non-privileged 'mtedge' user instead of root
    • Change default JWT token expiration interval to 12 hrs
  • Add support for filtering reports by labels
  • Add Import/Export option for Adapted LPs
  • Add Dictionary Caching upon Job Engine start
  • Add support for SAML attribute "emailaddress" for easier integration with Okta
  • Add REST API endpoint for SAML authentication (browser assisted) to allow support of SSO in plugins
  • Improve Kubernetes and Docker support to handle the latest 8.5.2 capabilities
  • Improve Kubernetes Deployment with Helm:
    • Allow override of any specific Translation Engine parameters from the Helm command line.
    • Ability to supply a license at deployment time (from an existing Kubernetes secret or local file).
    • Ability to override resource requests/limits for each individual Translation Engine.
    • Ability to use non-default, authenticated Docker registries, for example the one provided by RWS.
  • Fix pagination of large number of entries in the Dictionaries page
  • Fix poor translation of PDF→Text files for Arabic source
If you are already using MT Edge 8.5, you can safely upgrade to 8.5.2 and no new license is needed.
Direct upgrade from other 8.X previous releases is supported, but a MT Edge 8.5 license will be required. The new license can be requested through your gateway account, and it can be generated based on your current myhosts.json file (there is no need to wait for the upgrade to be done to get the license generated - we can generate the license in advance so it can be available when the upgrade is performed).
Please let us know if you have any question,
Thanks!
