SDL Machine Translation Edge 8.4.4 has been released
Hi all,
I'm happy to announce that SDL Machine Translation Edge 8.4.4 is now generally available.
This version is a patch release and it includes several fixes and improvements:
  • Performance improvements:
    • Improve throughput and reduce latency for small concurrent translations.
    • Use database write-ahead-logging to improve overall translation performance under heavy load.
  • LP Chaining improvements:
    • Chained LPs are now properly displayed in the Quick Translate UI after login
  • SAML support improvements:
    • Add SAML role-based authentication for Azure.
  • GroupShare Integration improvements:
    • Update GroupShare integration to create and use a Translation Memory for each project template.
    • Automatically perform check-in GroupShare files before downloading.
  • Trainer improvements:
    • Add UI option to retry a cancelled adapted LP training.
    • Support for training with large TMX files (up to 30 millions TUs)
  • Segmenter improvements:
    • Add support for new a new "Strict XML" mime-type (text/x-sdl-strict-xml) that forces segmentation after each XML tag.
    • Improve segmentation performance for large documents.
  • Language Detection improvements:
    • Improve Language Detection accuracy.
  • Various additional fixes and improvements
    • Change default RabbitMQ port to 5673 on new installations to avoid collisions with other RabbitMQ installations, and use non-default node name.
    • Fix dictionary support when using edge-cloud translation engines.
    • Preserve TLS settings on upgrade if they had been manually configured.
    • Various updates to improve licensing informational and error messages.
The online documentation has been updated and the installers are available on our download servers.
Thanks!
Arnaud
