SDL ETS - Test LDAP Configuration Failing to bind user
Context
Since the upgrade to SDL ETS 7.3.4 the Test LDAP Configuration is failing to bind the user if using Only this LDAP bind user can do a search option, despite SDL ETS being able to use these credentials to return Login Groups and users are able to authenticate into the system.
It is working correctly in SDL ETS 7.3.3:
Screenshot of Trados Studio's Test LDAP Configuration showing successful LDAP server connection and binding of bind user.
Not working in SDL ETS 7.3.4 and 7.3.5 (unless the Bind User Password is re-entered)
Screenshot of Trados Studio's Test LDAP Configuration with an error message 'Binding of bind user failed: Cannot bind user' and a code '49 invalid credentials'.
Root Cause
The problem has been raised to development under CRQ-9675
Resolution
Although Test LDAP Configuration is failing to bind the user once it has been saved, it will be working once the password is re-entered into Bind User Password field.
Reference
CRQ-9675
[edited by: Trados AI at 10:49 AM (GMT 0) on 4 Mar 2024]
