ETS - Following ETS 8.0.1 installation the Tranlsation Engine is stuck in "starting"
Symptoms/Context:
Following ETS 8.0.1 installation the Tranlsation Engine is stuck "starting"
[2018-07-30 16:51:17,584]INFO sdl.ets.Application - Logging started: SDL Enterprise Translation Server (ETS) v8.0.1 release [2018-07-30 16:51:18,008]INFO sdl.ets.Application - Starting the server in mode: TranslationEngine [2018-07-30 16:51:18,206]INFO sdl.ets.Decoder - Loading language-pair: /opt/sdl/ets/lps/JpnEng_Generic_SRV_PBL_8_0_x_0/config/XMTConfig.yml preload=1 [2018-07-30 16:52:16,335]INFO sdl.ets.Application - Logging started: SDL Enterprise Translation Server (ETS) v8.0.1 release [2018-07-30 16:52:16,727]INFO sdl.ets.Application - Starting the server in mode: TranslationEngine [2018-07-30 16:52:16,931]INFO sdl.ets.Decoder - Loading language-pair: /opt/sdl/ets/lps/JpnEng_Generic_SRV_PBL_8_0_x_0/config/XMTConfig.yml preload=1
Root Cause:
The NVIDIA drivers and/or Cuda 8 are not installed.
Resolution:
For the GPU configuration, both the NVIDIA drivers and Cuda need to installed if they haven’t already:
.Cuda 8
.Drivers (v384.66)
Once installed verify the GPU is detected by running the 'nvidia-smi' command and verifying it lists the K80 GPU as detected.
