API Access
How do I determine what Language Weaver subscription level I have? I want to find out if I have access to the Language Weaver API for accessing your cloud services. According to the Language Weaver documentation:
In order to get started developing on the cloud-based Language Weaver API, you need to create an account by visiting https://portal.languageweaver.com and signing up to plan that supports API integration. Once there, you can access your API credentials from the settings in your account.
If you’re already a Language Weaver customer with a valid subscription, you can manage your API credentials from https://portal.languageweaver.com/settings/api-credentials .
  • I'm a Language Weaver customer but how do I determine if I have a plan that supports API Integration.
