The client requests the translation in XLIFF format. the only option provided by Trados 21 is Word, the original files were sent in Word. what should I do to save the target as XLIFF?
Hi Gamila Hefny
You can use this app https://appstore.rws.com/Plugin/67 in the Files view right click on the docx.sdlxliff file you want to save and select Export to xliff, follow the steps from the Export window and then you will have the xliff at the location from the Summary (3) stage. In the last stage Preparation (4) you have the option Open Folder in Explorer, which should let you access the file location.
Hope this helps.
Kind regards,
Elisa Maxim| RWS Group
