Editing SDL Tridion Docs DITA files in Oxygen XML Editor
I am new to working with the SDL Tridion Docs connector to Oxygen XML Editor but am familiar with using Oxygen XML Editor to edit other DITA files. I am wondering if there is any further documentation/recommendations out there to help with the configuration steps involved in order to edit and test transforms of SDL Tridion DITA files more seamlessly inside Oxygen.
Any advice appreciated,
Regards,
Ann
  • If you already have an XML catalog which maps a custom DTD public ID to the customized DTD, your plugin just needs to refer to that XML Catalog:
    Hi Akheil,
    I believe my problem is with the use of a custom DTD which is referenced in the DOCTYPE declarations of the DITA map that I am working with e.g. <!DOCTYPE map PUBLIC "-//Ann//DTD DITA Map//EN" "annsMap.dtd"[]>
    I have a new Document Type Association in Oxygen called Anns DITA Map. Under the Association rules I have it associated it with the DOCTYPE  above. I also configured the Catalogs tab to point to the catalog.xml file that was supplied to me for this new type.
    When I create a new DIta map in Oxygen, I can see that the Document type property for this file is referring to the new type Anns DITA Map but when I try to transform this map via the Transformation Scenarios I get the following error (doctored to remove real names)
    Transformation failed. <path to DITA-OT>\plugins\org.dita.base\build_preprocess.xml:62: Failed to run pipeline: [DOTJ078F][FATAL] Input file 'file:/<path to DITA map>/file.ditamap' could not be loaded. Ensure that grammar files for this document type are referenced and installed properly. Cannot load file: <path to DITA map>\annsMap.dtd (The system cannot find the file specified)
    Do you have any idea what configuration step I am missing?
    Ann
  • Hi Ann,
    Does an OOTB concept publish to DITA-OT from Oxygen without issues? If using a custom DTD, it needs to be referenced in catalog-dita.xml (Located in C:\Program Files\Oxygen XML Author 20\frameworks\dita\DITA-OT2.x)
    The reference would look something like this.
    <nextCatalog catalog="../../../../../Users/<username>/AppData/Local/SDL/InfoShare Client/0108813335/Config/DocTypes/catalog.xml"/>
    Akheil
  • Thank you Akheil, I followed your instructions above and the transform of a DITA file using a custom DTD is now working in Oxygen.
    Next is to try the same with a custom DITA-OT. I want to understand the impact of the different configuration elements within Oxygen.
    Much appreciated,
    Ann
